Power Steering
Old Feb 7, 2011 | 02:30 PM
txmusic's Avatar
Default Power Steering
My wife has a 2005 Accord V6. The power steering was making a lot of noise so I figured it was the pump. I replaced the pump and it still made the same noise, so I thought maybe I had just got a bad pump. I exchanged the pump for another new one. Also, I didn’t realize that Honda required a specific power steering fluid, so on the second replacement I used the correct fluid. I also blew all of the old fluid out of the lines with an air hose. After the second replacement pump it is still making the same noise. Any thoughts?
Old Feb 7, 2011 | 04:23 PM
Noises are hard to figure out on the net.
Groaning? Squeaking? Clattering?
While it's making the noise, does the steering work OK? Loose? Excessive friction?
And this belongs in General Tech (read the sticky threads in each area) so I'll move it.
Old Feb 7, 2011 | 04:49 PM
txmusic's Avatar
Sorry about that. Thanks for moving.
It's a constant squealing noise that seems to be coming from the pump. Not a belt though. The power steering works, but isn't as smooth as normal.
Old Feb 7, 2011 | 04:52 PM
txmusic's Avatar
As mentioned, this is a 2005 Accord. It's got the 3.0 V6 and it's an automatic transmission.
Old Feb 7, 2011 | 08:33 PM
EXV6NIGHTHAWK's Avatar
Here is the likely solution to your problem. Easy $2.00 fix.
Old Feb 7, 2011 | 08:36 PM
Here's a how-to with pictures to help also. Hope it works out. There was probably nothing wrong with your original pump.
http://www.driveaccord.net/forums/sh...ad.php?t=42915
Old Feb 7, 2011 | 09:50 PM
txmusic's Avatar
The O Ring did the trick! Thanks! I just wish I would have known that several hours and dollars ago. Oh well, you live and you learn.
Thanks again!
amajakgar
Aug 9, 2014 09:22 AM
loki16
Aug 12, 2013 06:54 AM
darkgreen18290
Jun 25, 2013 07:51 AM
Planefreak
Nov 15, 2007 02:52 PM
