Power steering fluid flush
Old Sep 15, 2010 | 07:48 PM
fdte320's Avatar
Question Power steering fluid flush
I've searched for an answer to this topic but can't find none. I have a '98 LX, 213,000 miles. Bought 5 bottles of power steering fluid. The fluid in the bottles are clear. First, I drain the container of the old fluid by disconnecting the bottom hose, fill it up with new fluid, start the car, turn steering wheel lock to lock. Then drain again. But everytime I drain, the fluid comes out to be very dark. I did this till I run out of fluid (5 bottles). Still the fluid is dark after I run the engine. Is this normal or do I need to flush more. Appreciate any guide/comments.
Old Sep 15, 2010 | 07:52 PM
Your problem is a filter pad in the bottom of the reservoir that contaminates your new fluid w/ dark particles. Fluid is probably fine, but doesn't look nice and clean. A new reservoir may help (pad is not accessible to clean or replace). However, there may be contaminates inside the steering rack.
Old Sep 16, 2010 | 08:52 AM
I thought there's a fine mesh screen down in the reservoir. I've cleaned it out, it wasn't a filter pad, it came clean without much difficulty. Maybe certain years it's different?
Old Sep 16, 2010 | 02:07 PM
fdte320's Avatar
Thanks guys for the response. There is a filter mesh screen at the bottom of the reservoir which i cleaned easily but fluid still is dark after the flushes. Any Idea?
Old Sep 16, 2010 | 11:09 PM
bigdawg74's Avatar
My guess is that after about the 3rd bottle, you were wasting good PS fluid. They get dark. Sleep better at night knowing that your fluid is in better shape now than it was before.
Old Sep 17, 2010 | 06:58 AM
buckeyeboy's Avatar
I have started draining and filling the power steering fluid reservoir every oil change since 50K. It was Coca Cola colored then. And once every summer I go through a complete system changeover, using 3 bottles of fluid. I was initially a bit discouraged that the light yellow color would not last very long, but I knew that the new fluid mix was better than before. My guess was older darker fluid still leftover in the rack would mix with new over time. But over the last two years of changes, the fluid has gotten and stayed light yellow.
Old Sep 17, 2010 | 10:01 AM
fdte320's Avatar
Thanks BigD. Anyway it only cost me $3.00 per bottle. Buckeye, good idea to change it at every oil change. I think I'll just do that. Two years?
Old Sep 18, 2010 | 12:59 AM
bigdawg74's Avatar
Hey, after reading my post, I think I was a little harsh on ya. Sorry about that. Personally, I think changing PS fluid at every oil change is a little bit of overkill...maybe once a year or every other year. But everybody's idea here is different, and that is what makes us great.
Old Sep 20, 2010 | 10:34 AM
fdte320's Avatar
No problem BigD. Non taken. I believe this is why we have a forum - to exchange ideas & offer help/suggestion. Like you said everybody have his/her own idea. These ideas are what will help others decide what regimen to follow on their cars. Again, appreciate all the ideas/suggestions/responses.
62maxx
Oct 18, 2015 08:20 AM
nyaccodguy
Mar 17, 2015 06:38 PM
mpanelli
Nov 2, 2013 07:30 AM
dtcaccord
Jun 4, 2008 09:54 PM
brittanym06
Nov 5, 2007 03:40 PM
