Power Steering Problems
Old Feb 9, 2012 | 05:53 PM
VTuT2734's Avatar
Cool Power Steering Problems
I have a 1999 Honda Accord Ex 4cyl. I have currently replaced my power steering pump, high pressure line, power steering reservoir, line from reservoir to pump and power steering belt. Last year I got a new steering rack. I am still getting that dreadful schreeching and foamy fluid in my reservoir. I have read it may be a o-ring but where? I think its coming in on the return in order to get a foamy fluid into the tank. Any ideas of what I should do or anyone that has had this problem? Been looking into changing out other lines throughout the system off a schematic I found. Any ideas are greatly appreciated. Thanks for the help.
Seth
Old Feb 9, 2012 | 07:00 PM
There's an oring under the intake (suction) side fitting. Make sure the suction hose and end clamps are sound and not allowing air to enter anywhere.
Old Feb 9, 2012 | 07:29 PM
VTuT2734's Avatar
Is that onto the powersteering pump where the hose clamps onto it coming from the reservoir?
Old Feb 9, 2012 | 10:07 PM
That is correct.
Old Feb 10, 2012 | 06:39 PM
VTuT2734's Avatar
Nothing there to put one on. The end is flanged so the tube goes over it. Still whinning like crazy. It moves freely when I turn so it has to be pumping but whines all the time and holds most of the fluid.
Old Feb 10, 2012 | 07:00 PM
I took a look at your pump on Majestic Honda and looks like suction nipple is part of pump body and not removable.
Look for loose clamp, loose hose end, punctured hose allowing air in. Problem remains same air in fluid which can only get in on suction side of pump.
loki16
Aug 12, 2013 06:54 AM
darkgreen18290
Jun 25, 2013 07:51 AM
Mr.Project8
Aug 5, 2010 10:33 PM
Planefreak
Nov 15, 2007 02:52 PM
coolgmslife
Mar 26, 2007 11:53 PM
