Power Steering Pump
Old Oct 18, 2006 | 07:37 AM
lightshow's Avatar
Default RE: Power Steering Pump
if the racks not leaking then it is probably fine. there is an adjustment on the rack. check your chiltons...... it is right on the bottom of the rack under the plate. i think a couple 10mms take the plate off. then there is a double bolt. if you loosen it....it reduces effort to spin the rack and if you tighten it (clockwise) it will increase the effort.
Old Oct 18, 2006 | 08:18 AM
YeuEmMaiMai's Avatar
what failed on your other pump that caused you to replace it? It is possible that you can have peices of pump in your rack.....
Old Oct 18, 2006 | 09:38 AM
WhyNotFab's Avatar
the bearing was completely gone in the old pump, you could move the pully around (not spining) easily with your hand.. and while turning, it was loud grinding and leaking fluid out of the front
WhyNotFab
Sep 30, 2006 05:25 AM
Rizzie
Aug 21, 2006 03:26 AM
BDN54
Mar 9, 2006 02:34 PM
WS6M21
Dec 4, 2005 11:37 PM
WS6M21
Nov 9, 2005 01:50 AM
