power steering pump replacement
ok so it's time to replace my power steering pump. I plan to do it myself but do not want to mess up belts/adjustment(bolt?)...It seems like it should be a relatively easy fix. I did some research and apparently I need all kinds of tools(for the belt and what not). I don't wanna mess anything up with adjustment. Any tips would be appreciated. thanks!
ps- she's a 96 Accord LX 4cyl
Why are you replacing the PS pump? They are very reliable and very rarely fail?
Removal is straightforward, but you will have to loosen/remove the drive belt.
Tools: You will need a 12mm closed end and 12mm ratchet/socket.
Suggest downloading the 94 Accord manual (PS is same) from the Online Manuals links in DIY forum. This provides a step/step w/ images.
