power steering removal
Old May 9, 2006 | 05:14 PM
vdabis
Default power steering removal
what is the proper way to disconnect the power steering on a 92 Accord LX and retain the rack? I have read several different ways and now I'm confused. At the rack there are three hard lines. One is for the pressure switch. Which lines should I tee up and vent? Or can I just plug the pressure switch and tee & vent the two remaining lines.
Old May 9, 2006 | 07:04 PM
lightshow's Avatar
Default RE: power steering removal
so you want to take the pump out?
Old May 10, 2006 | 04:33 AM
deserthonda's Avatar
ORIGINAL: vdabis
do you want to totally remove system from car ?? or make it so it is not working ?
Old May 11, 2006 | 12:18 AM
vdabis
Both. I removed everything except the rack. I need to know the proper way to close up the lines so that I can still use it. I read some where that you need to tee off the two open lines and vent it but I don't know what to do with the line that has the switch attached to it. I appreciate any insight on this!
loki16
Aug 12, 2013 06:54 AM
darkgreen18290
Jun 25, 2013 07:51 AM
Accord1999
Dec 18, 2012 09:41 PM
creator1322
Dec 6, 2010 03:40 AM
Planefreak
Nov 15, 2007 02:52 PM
