93 H22A1 swap into 92 Accord LX
Old May 9, 2006 | 01:31 AM
vdabis
Default 93 H22A1 swap into 92 Accord LX
Need some advise. I am using the Accord M/T trans mount and bracket on the M2S4 Prelude M/T. Without the mount attached the clearance between the crank pulley and frame is normal but once I bolt up the trans mount, the engine shifts to the right and the crank pulley is pressed against the frame. I had this same setup when it was attached to the F22A1 engine and it to had clearance problems with the crank pulley. Should I dump the Accord mount and use a Prelude instead. Will this take care of this problem?
Old May 9, 2006 | 07:09 PM
lightshow's Avatar
Default RE: 93 H22A1 swap into 92 Accord LX
you should use the accord mount. you may have a totally different problem
Old May 11, 2006 | 12:27 AM
vdabis
I found out what the problem is. Even though the H22A is a drop in swap for the 4G/5G Accords, if your car is an automatic then you must change the mount bracket thats welded to the frame and replace it with P/N # 60831-SM4-300ZZ. So, if you want a hassle free swap its best to go with an Accord that has your choice of transmission!
alexdc
Jun 16, 2010 07:17 PM
HondaAccordEX94
Mar 28, 2010 10:16 PM
VTECSK8R88
Mar 19, 2009 09:03 PM
live2rice
Jan 11, 2008 01:12 PM
vdabis
May 2, 2006 02:42 AM
