Power window problems
Old Jun 11, 2008 | 03:57 AM
BlackGoose
Default Power window problems
hey whats good everyone? I ve got a 1995 Accord 2 door Coupe, 2.2L non vtech that i picked up for a steal of $2400 but my driver side power window doesnt work. I can push it up and down with my hands but the regulator isnt working. I took the door panel off today and tried to see if it was faulty wiring or if the motor was burnt out, but the motor seems to be working, but when i try to put the window down or up, the regulator cable barely pulls in or releases and then i hear a grinding noise and then the motor gives up. Do you think i need a new regulator? motor? track? or something else i dont know about? help me out everybody, thanks a bunch
matt
Old Jun 11, 2008 | 06:36 PM
finch13's Avatar
Default RE: Power window problems
Clean the tracks with rubbing alcohol and lube 'em up with silicone lube.
Old Jun 11, 2008 | 06:53 PM
deserthonda's Avatar
I am afraid that the cleaning stuff won't do in this case, motor/regul comes as a unit and i bet that it is your problem,, part from the dealer is around $ 150-160 ( reg+ motor ) part # 72250-SV2-003. you might want to try to find one cheaper ,, but if only 40-50 dollars difference ,I would go with Honda parts
Old Jun 11, 2008 | 07:35 PM
finch13's Avatar
I meant to suggest the cleaning first and then change out the regulator if it doesn't work.
camcyddev
Sep 26, 2013 05:09 PM
jkeely
May 2, 2012 03:48 PM
Opballer
Feb 9, 2012 11:54 PM
drew and not u
Jun 24, 2008 01:25 PM
mmazb3
Nov 26, 2007 03:16 PM
