Power Windows
Old Mar 13, 2006 | 07:57 PM
sir_nasty's Avatar
Default Power Windows
1994 Accord... the power windows aren't working so well.... I've found that if I stop the car and just sit there and try to put them up at idle the drivers side goes up to about 1/4" from the rubber seal and then stops, no noises nothing, if I roll it back down and try again usually the same issue happens, however if I rev the engine to around 2-3k then do it they go up fine... I'm guessing a voltage regulator or something?
Also, my passenger side window switch is wired backwards so down is up, up is down... I'm guessing I can fix both issues in one shot?
Old Mar 14, 2006 | 01:55 PM
sir_nasty's Avatar
Default RE: Power Windows
Any suggestions on these issues? I did some further testing and it seems to be a more prevelant problem on the driver side than the passenger if that helps any....
Old Mar 14, 2006 | 07:09 PM
lightshow's Avatar
yea the drivers side motor just usually gets the most use so it goes out first. the motor is just old and doesnt have the power that it once had. its about 100 bucks to change it out your self
Old Mar 15, 2006 | 05:03 PM
sir_nasty's Avatar
is that from a junk yard or new? I suppose I'll just buy one soon and pull the door panels and do it... do you think I could reverse the wiring for the passenger side switch from there or will I have to pull the passenger door as well?
Old Mar 15, 2006 | 05:29 PM
lightshow's Avatar
yea brand new from checker its like 100- 120 bucks. just take the door panel off, and unscrew the glass from the regulator and then pull the whole regulator off. ive done this many times let me know if you have any questions. i have a question for you. is the switch reversed just from the drivers door, or it it also mixed up with the passenger side switch also. if its just the drivers switch then it can be fixed from the drivers side. if the pass switch is also messed up you might have the problem in the passenger side.
Old Mar 15, 2006 | 05:31 PM
sir_nasty's Avatar
both sides are screwey.... I'm guessing it's reversed at the passenger side motor based on what you said etc.... If I do it I'll post pictures/steps.... Cash is a bit tight right now so It's another "future idea..." lister..
falge
Mar 11, 2008 06:47 PM
th22ek9
Sep 13, 2006 11:11 PM
th22ek9
Sep 8, 2006 09:07 PM
ButtonMan
Jul 4, 2006 11:51 AM
smoovekriminal
Apr 22, 2006 12:28 PM
