problem on handling
Old Oct 19, 2006 | 02:58 AM
trukid21's Avatar
Default problem on handling
hey guys, I recently replaced my half shaft cv joint of the driver side, (96 4cyl,manual with abs) afterwards i noticed that when i accelerate within 50 to 60 mph the car would vibrate then settles down around 65. so i had the alignment checked and it was fine, then i balanced the tires and found some faults,fixed that. I drove it again and it still slightly vibrates at the same speed,not as bad but still noticeable. before i replaced the half shaft this was non existent,now the shaft has been replaced then this happened.could you help me with this one.i rechecked all the bolts connections for looseness i even torgue the bolts to proper specs but i did not see anything wrong with it. need help..
Old Oct 19, 2006 | 03:37 AM
miki's Avatar
Default RE: problem on handling
could your rim be bent somewhere?
my best guess
Old Oct 19, 2006 | 05:32 AM
YeuEmMaiMai's Avatar
you sure you got the right half shaft in there?
Old Oct 20, 2006 | 01:28 AM
trukid21's Avatar
yup, i have the right one in there.and no i don't have a bent rim either.this problem started right after i replaced the half-shaft on the same day when i took the car for a road test .that's why i'm confuse.is there any other possibilities.
zero5
Apr 7, 2008 09:58 PM
reinventingaxlrose
Jan 2, 2008 08:37 PM
deathcrow
Sep 5, 2007 11:09 AM
customcreazn
Jan 30, 2007 03:41 PM
RTexasF
Mar 6, 2005 11:59 AM
