problem starting car after 5 days
Old Apr 1, 2011 | 08:00 PM
stevebsm's Avatar
Default problem starting car after 5 days
Have a 2000 accord replaced battery,checked starter and alternator all fine nothing plugged to ac,stock stereo. But still having problems starting after 4 or 5 days just clicking when trying to start.Could something else be draining power? any suggestions? thank you
Old Apr 1, 2011 | 08:38 PM
This could mean poor battery connections, weak battery, of bad starter solenoid contacts.
Check battery connections for clean, secure connection.
Check battery voltage after 4-5 days. Batterys sometimes develop internal shorts that pull the voltage down after some time.
If connections and battery check OK, then starter may have weak solenoid contacts. This will cause the starter to click, even w/ a good strong battery.
Does jump starting the battery allow the car to start?
Old Apr 2, 2011 | 08:09 PM
stevebsm's Avatar
When i jump start it works right away
Old Apr 2, 2011 | 08:19 PM
Since you have a new battery, something is drawing current from the battery and draining it.
You will need a volt meter to test for amps. Then you will start pulling fuses to isolate what is drawing the current from your battery.
Copy and past this into your browser to see how to use the volt meter to find the draw.
Once you find out how much current is being drawn, I would unplug the alternator to see if that is drawing current, then move to pulling fuses to isolate the draw.
flashoffroad.com/electrical/Batteries/BatteryDrain.html
Old Apr 3, 2011 | 07:56 PM
stevebsm's Avatar
thanks for the info i will try that and let you know if it solves my problem
shook
Jan 26, 2012 02:52 PM
motleyman
Mar 1, 2011 10:35 PM
nma_re
Jul 6, 2009 06:15 PM
kellysa111
May 1, 2009 08:35 AM
dknight211
Dec 29, 2007 12:48 PM
