problems with front windows accord ex sedan 2003
Old Sep 3, 2014 | 05:02 PM
jcuebas's Avatar
Default problems with front windows accord ex sedan 2003
Good evening I have some problems with the front windows on my accord not one from the front works at all check the fuses and they dont have power means 26 and 27 did the motors test and nothing happens can somebody help me please
Old Sep 3, 2014 | 05:16 PM
I've moved this to General Tech - please don't post questions in the DIY section.
Old Sep 3, 2014 | 05:23 PM
Thank You poorman..way to put it in there..
Old Sep 4, 2014 | 09:44 AM
If under-dash Fuse No. 27 doesn't have power, then check under-hood Fuse No. 23 (50A).
Under-dash Fuse No. 27 supplies power to under-dash Fuse No. 24 (left rear window), No. 25 (right rear window), and No. 26 (right front window) via the power window relay. So, if Fuse No. 27 has no power, none of your power windows should work; not just your front windows.
Also, what exactly did you do as a motor test, apply direct power and ground to each window motor?
Old Sep 4, 2014 | 05:39 PM
jcuebas's Avatar
yes i found some info in this forum that shows how to do the test
Old Sep 4, 2014 | 05:43 PM
Which test?
I post different tests for the power windows; by applying direct power and ground to the motor and/or using a jumper wire on the driver's door multiplex control unit (mcu).
Old Sep 4, 2014 | 07:40 PM
jcuebas's Avatar
I think those r the test I run but dont work there's had to be someting bad cause the steering wheel controls for the radio didnt work either
vkbr
Aug 10, 2013 10:47 AM
robdog13
May 22, 2011 06:20 PM
th22ek9
Sep 13, 2006 11:11 PM
th22ek9
Sep 8, 2006 09:07 PM
