Programming Keyless Entry Remote
Old Jun 2, 2006 | 05:54 PM
St3v3
Default Programming Keyless Entry Remote
1997 Honda Accord special edition. My remote went dead, installed new battery...How do I program it again? Thanks for any help.
Old Jun 2, 2006 | 05:59 PM
sir_nasty's Avatar
Default RE: Programming Keyless Entry Remote
I'll see what else I can find but with some remotes you can just point it at the car and press the key you want to program 6 times in a row and it will re-program it.... give that a shot first... Let me know if it worked
Old Jun 2, 2006 | 06:01 PM
sir_nasty's Avatar
I found the directions...
Ok...try this to reprogram so you dont need to pay all that money!
1. Turn the ignition switch on (II on the ignition)
2. W/in 1-4sec, push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit. (Just at the steering wheel is fine)
3. W/in 1-4sec, turn the ignition switch off
4. W/in 1-4sec, turn the ignition switch on(II)
5. W/in 1-4, push the transmitter lock or unlock button w/ the transmitter aimed at the receiver again.
6. W/in 1-4sec, turn the ign. switch off
7. W/in 4sec, turn the ignition switch On(II)
8. w/in 1-4sec, push the transmitter lock or unlock again.
9. w/in 4 sec, turn the ign off
10. w/in 4 sec, turn the ign ON
11. W/in 1-4, push the transmitter again
12. Confirm you can hear the sound of the door actuators. W/in 1-4sec, push the trans lock or unlock button again.
13. W/in 10sec, aim the transmitters (up to three) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch off, and pull out the key.
15. Confirm proper operation with the new codes
There you go! Sorry this is from the helms but my scanner is broken right now.
Jeffrimerman
Aug 4, 2009 04:36 PM
samijean55
Jul 28, 2008 09:48 PM
deserthonda
Feb 23, 2007 06:08 PM
IUHooshur
Jan 4, 2006 12:04 PM
93Miata
Nov 10, 2005 08:06 AM
