Pulley Kit Swap??
No they dont work on whips, whips dont have mechanical parts. There is a ralco pulley set that goes on the 04, i just ordered them. The one that fits our gen accords fit the ones for rsx. http://www.ultrarev.com/product.php?productid=80306
Waste of money in my opinion. Your a/c probably won't blow as cold and your alternator will not put out as much voltage. I don't think i have ever seen a good review on a pulley kit for a 4cyl Accord.
ORIGINAL: 00AccordLX5spd
I should have them by the middle of next week, ill give a you an idea of if its worth it or not.
If allthe pulleys turn slower, the AC clutch will operate a greater % of time. Pressures, therefore temperatures, should be the same.
Alternator also turns slower. Some people won't tolerate dimming headlights at idle. For me that would be OK since I know to expect it.
If it concerns you, get a lightened set that is OEM size. That's what I have .... this time around. On the accord, I had the UR underdriven set and never had any problems .... also with 2 amps .... total RMS = 550W
ORIGINAL: 03Sleeper
You'll only lose A/C coolness, etc. with Underdrive and even so, its not that big of a deal. I think the Ralco ones are stock sized so no problems should occur.
accordfan222
Oct 14, 2007 07:19 AM
