Pulley Kit Swap??
Old Jun 18, 2008 | 08:03 PM
accordexcoupe
Default Pulley Kit Swap??
I cant find a pulley kit for my 2004 accord ex 2.4l but they do have it for the 04 TSX, as far as i know its the same engine minus tuning.... Can i use that kit on my whip?
Old Jun 19, 2008 | 08:15 AM
Fenix's Avatar
Default RE: Pulley Kit Swap??
No they dont work on whips, whips dont have mechanical parts. There is a ralco pulley set that goes on the 04, i just ordered them. The one that fits our gen accords fit the ones for rsx. http://www.ultrarev.com/product.php?productid=80306
Old Jun 19, 2008 | 10:52 AM
00AccordLX5spd's Avatar
Registered User
Waste of money in my opinion. Your a/c probably won't blow as cold and your alternator will not put out as much voltage. I don't think i have ever seen a good review on a pulley kit for a 4cyl Accord.
Old Jun 19, 2008 | 02:28 PM
Fenix's Avatar
ORIGINAL: 00AccordLX5spd
See ive heard just the opposite, several guys over at V6p put them on their 4cyl and said that their acceleration has improved. As far as the AC blowing cold, IDK. For me its useless, i never use my AC, i prefer having the windows down.
I should have them by the middle of next week, ill give a you an idea of if its worth it or not.
Old Jun 19, 2008 | 03:52 PM
If allthe pulleys turn slower, the AC clutch will operate a greater % of time. Pressures, therefore temperatures, should be the same.
Alternator also turns slower. Some people won't tolerate dimming headlights at idle. For me that would be OK since I know to expect it.
Old Jun 19, 2008 | 05:16 PM
falkore24's Avatar
If it concerns you, get a lightened set that is OEM size. That's what I have .... this time around. On the accord, I had the UR underdriven set and never had any problems .... also with 2 amps .... total RMS = 550W
Old Jun 20, 2008 | 12:28 AM
nafango2's Avatar
or just put larger pulleys on the power steering pump and alt and leave the A/C where its at.
Old Jun 20, 2008 | 08:13 PM
03Sleeper's Avatar
You'll only lose A/C coolness, etc. with Underdrive and even so, its not that big of a deal. I think the Ralco ones are stock sized so no problems should occur.
Old Jun 23, 2008 | 09:33 AM
falkore24's Avatar
ORIGINAL: 03Sleeper
As Jim stated, AC works on specific fluid pressures. The compressor will work slower but for more time. The result will be a bit less AC on the hottest days only. Normally, there won't be any differance since an AC system is sized for the worst case scenario, yet hardly ever sees it. Unless you live in the desert or bayou, the underdriven pulley won't noticably affect your AC.
Skott83
Apr 6, 2008 10:03 AM
srpowersuw
Dec 3, 2007 05:23 PM
accordfan222
Oct 14, 2007 07:19 AM
srpowersuw
Oct 10, 2007 06:44 PM
frankiexthedork
Sep 14, 2007 07:54 AM
