pulsating brakes
Did you clean all the corrosion off the hub before you installed the rotor? Corrosion can have the rotor sit out of parallel and cause a vibration.
Did you clean the caliper bracket where the hardware clips in, so the brake pads can slide with little resistance? Did you install new brake hardware clips? A bound brake pad could heat up the rotor and cause warping.
This YouTube channel is really good. He covers a complete front brake job on an accord.
