Pumping Gas Question
Old Aug 20, 2007 | 10:23 PM
  #21
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Aug 30, 2007 | 05:42 PM
  #22
SIXPAK GQ's Avatar
Default RE: Pumping Gas Question
Is it ok to fill the tank to FULL?
Old Aug 31, 2007 | 12:10 AM
  #23
Amtrak288's Avatar
Only once did I ever see my low-fuel light come on, I actually wanted to get most of the "old gas" out of the car since it was in late April and most gas stations in this part of Western New York had now switched to the "summer blend". When I stopped at a Sunoco station to fill the tank, the fuel light was on, though it was only on for maybe 15 miles. I filled the tank and it only took maybe 13 1/2 gallons! The '06 Accord fuel tank holds 17.09gallons! Normally, Ifill up when the needlegets just below half a tank unless I'm on a road trip then Ifill up at about 1/4 tank, tooafraid to go any lower than that! Filled up tonight, I have the 4 Cylinder engine in my Accord and got 33.64mpg!
Old Aug 31, 2007 | 09:14 AM
  #24
deserthonda's Avatar
ORIGINAL: SIXPAK GQ
of course ,,,till it clicks ,, just do not keep on putting in gas once the nozzle has clicked ,, if you overfill it way too much ,, it could cause some evap system components to fail
Old Aug 31, 2007 | 06:39 PM
  #25
bustum's Avatar
This was an informative liitle thread, thanks for the tips guys.
I've got a question - does anyone know about or use pure acetone in their tanks and if so, is it really safe? I understand that adding about two ounces to every 10 gallons will DRAMATICALLY increase fuel economy. You can supposedly go from around 21-22 mpg to 32-33 mpg. I have a link to the info if it is not already a well known and either accepted or discouraged thing.
Old Aug 31, 2007 | 07:28 PM
  #26
MPG is about energy content. If you use ethel alcohol w/ 10% less btu/gallon, your gas mileage decreases correspondingly. For acetone to yield 30% higher mpg would require a dramatic amount of energy from somewhere.
A quick google yields many touts, buta few rigorous tests; Mythbusters and Kettering University. I could believe perhaps a small improvement due to improved gas:air mixing, perhaps 1-5%, but higher than that seems unlikely. Fuel efficiency improvements in the < 5% range are difficult to detect since they represent only a few miles per tank. It's easy to deceive yourself. See following interesting blogger w/ both sides presented pretty evenly.
http://neubranderinc.com/blog/2006/0...neering-rigor/
I doubt that 2-3 oz/tank of acetone will affect orings since the dilution is very high, approximately 500-600:1.
regards
Old Aug 31, 2007 | 10:05 PM
  #27
bustum's Avatar
ORIGINAL: TexasHonda
regards
Interesting read. By the comments, some believe they proved it worked for themselves while others are doubters based on science. I don't know what to believe, but if it won't hurt my car, then I might try it. Here is the link I saw pertaining to this subject:
http://www.metacafe.com/watch/524517...as_mileage_2x/
driftdoggy
May 23, 2013 11:16 PM
Hangfire79
Apr 4, 2013 07:07 AM
mdg
Jun 27, 2012 08:01 AM
dcsmith
Mar 21, 2008 07:02 PM
BostonPuppyDawg
Oct 3, 2006 01:24 AM
