puta puta puta puta puta
so just got a 96 accord LX I4 and for some reason whenever im going 50+ mph the engine makes this puta puta puta puta puta sound. it also happens when i let off the gas all the way going 30+ mph.
Is this normal? My original thought was a problem with the exhaust, but it sounds more like its coming from the engine.
So am i just paranoid, or is this an actual problem?
Any help would be greatly appreciated.
again, a 96 accord LX F22B2 w/ 88k
well i actually found the problem, i guess the axel boot is cracked.
I read a sticky that said something about that, however it said that you get that sound when you turn sharply, wheras ive always gotten in when im going fast or slowing down w/o the brakes.
Basically my car was in the shop to get the timing belt and water pump replaced, and they listed off all of these things that were wrong with it, and one was the axel boot, so problem solved.
Argh, though, it needs a new oil pan gasket, power steering pump, axel, and new plugs/valve seat gasket(s).
thanks anyway.
So basically im having the dealer fix the axel boot and plugs/valve seat gaskets because one is critical (axel) and one is cheap (plugs/valve seat gasket), but the oil pan gasket i can replace and the power steering pump i can do myself.
thanks anyway.
