Pwr Door Lock Buzzzzzz
Old May 15, 2007 | 05:39 PM
Pauls95's Avatar
Default Pwr Door Lock Buzzzzzz
my next project is fixingthe driver's side power door lock on my 95 accord ex. when i hit the lock switch to lock the door (not unlock), it makes this high-pitched buzzing/whining noise. i'm assuming that means that power lock is going out, but not positive??? is there a remedy for this? if it needs replacement, how difficult is it?
Old May 15, 2007 | 07:06 PM
hondadude's Avatar
Default RE: Pwr Door Lock Buzzzzzz
they can usually be repaired, inside the lock actuator there is a plastic tab that retains a spring. the plastic tab breaks loose, then the spring doesn't have enough tension.
Iused to epoxy 1/2 dozen little tinywashers behind the plastic tab to hold it in place.
it's not really that tough of a job to remove the actuator, 3 #1 phillips screws and unhook it from it's linkage.
Doublel
Mar 11, 2013 07:57 AM
bigdawg74
Jan 23, 2009 11:37 AM
zoominhuman
Mar 23, 2007 10:29 PM
19Accord97
Mar 20, 2007 05:14 PM
cbudgo
Mar 3, 2007 05:49 PM
