Pwr window/lock not working
Old Jan 22, 2009 | 07:53 AM
bigdawg74's Avatar
Default Pwr window/lock not working
On my '90 Accord, the front passenger side power window and power door lock does not work. All three other windows/locks work fine. When you push the window switch on the drivers door, the window moves maybe just 1/16" and stops. You can hear the mechanism wanting to work. The lock I just operate manually. Any thoughts at what I should look at first (then 2nd/3rd/4th)?Thanks for the help.
Old Jan 23, 2009 | 08:00 AM
bigdawg74's Avatar
Default RE: Pwr window/lock not working
Anybody??
Old Jan 23, 2009 | 11:37 AM
adealdds's Avatar
Not sure is this can help, but i had similar problems with my car (1997 accord).
For the window, try cleaning the window tracks with q-tips and IPA (alcohol), then spray some kind of lubricant (silicone) inside the track, this make your window move faster.
For the door lock, i believe there is a small piece of rubber inside the motor that usually fails and that you will need to replace, to do this, you need to remove the door panel, take the motor out, open it and fix it. There are some DIY instructions somewhere in this forum.
Take a look at this too: http://www.caraudiohelp.com/legendfo...tuator_fix.htm
Good luck
oldbeek
Jun 4, 2013 07:51 PM
Pauls95
May 15, 2007 07:06 PM
zoominhuman
Mar 23, 2007 10:29 PM
19Accord97
Mar 20, 2007 05:14 PM
cbudgo
Mar 3, 2007 05:49 PM
