Question regarding vacuum line
Old Feb 23, 2016 | 11:08 PM
bigdaddy6928's Avatar
Default Question regarding vacuum line
I got a 98 honda accord and there is a vacuum line coming from the transmission and it goes up and theres a place where it clips on to the radiator hoes then the line is cut. Does anyone know where this vacuum line would go to
Old Feb 24, 2016 | 08:02 AM
There's a breather hose (#7 in the picture). If that's the hose you're talking about, it's supposed to be open. I think the open end of the hose turns downwards or gets tucked into a bracket somehow, so it doesn't get full of water or crud.
Old Feb 24, 2016 | 12:37 PM
BlackLX4's Avatar
That might be the same one that's cut on our car. Good to know!
Old Feb 25, 2016 | 07:32 AM
Look at the line in that drawing, showing which hose-nipple it connects to on the transmission case. That's how to tell if it's the same hose you're looking at on your car.
Old Feb 25, 2016 | 08:25 AM
BlackLX4's Avatar
So out of curiosity, where would that hose normally connect, and for what purpose?
Old Feb 26, 2016 | 10:57 AM
The picture shows one end connected to a hose nipple on the transmission. The other end is open to the air. The purpose is to vent the transmission case. It should be clipped into some kind of bracket shown in the picture (#9), which simply holds in it place but leaves the end open.
Nearly everything in the car has to have some kind of vent. Tiny pinholes are incorporated in the brake fluid reservoir cap, battery caps, etc. The engine crankcase vents through the PCV valve. This is how they prevent the transmission from creating pressure or vacuum inside it's case as it heats up & cools down.
Old Feb 26, 2016 | 03:16 PM
Spinning/moving parts in a closed case will cause pressure changes, so there has to be a vent to equillibrate the pressure.
Drpepper
Sep 25, 2012 11:42 AM
Pattywagon
Jan 24, 2012 07:05 PM
swiftymorgan
May 30, 2010 03:59 PM
ohanahorse
Sep 28, 2009 08:49 AM
ohanahorse
Sep 15, 2009 10:38 AM
