Quick check for bad ignition switch
Old Apr 14, 2008 | 10:39 PM
Brahms's Avatar
Default Quick check for bad ignition switch
My wife discovered a quick and nasty diagnostic procedure for a bad ignition switch. Her Accord's symptoms were classic: intermittent stall unrelated to road speed or RPM, occasional non-start, you get the picture. Her insight (no pun intended):
Turn the key to the start position. When the starter starts to turn, let go of the key, allowing it to snap back to the run position. If the instrument warning lights go out, the switch is bad.
This seems to work on a couple of different cars, one with a known bad switch and one on the way downhill. And, by the way, the All-Knowing Honda Dealer Computer System insists that the ignition switch recall has been performed on both.
Old Apr 14, 2008 | 11:20 PM
Default RE: Quick check for bad ignition switch
Yeah, that probably gets the key to rotate further 'back'.
Another test is wiggling the key or holding it just barely into the spring-loaded part of it's rotation. Not far enough for the starter to keep running.
Matthew Kniss
Jun 30, 2014 06:00 PM
mclasser
Jan 5, 2014 05:13 PM
rizico
Oct 28, 2013 03:56 PM
giulio76
Dec 29, 2012 11:16 AM
jesandrw
Dec 8, 2011 09:48 AM
