Quick Question on EGR Port Drill/Piping
Old Apr 18, 2013 | 09:08 AM
5.0stang's Avatar
Default Quick Question on EGR Port Drill/Piping
I bought the kit and am going to knock this out this weekend. Is the only EGR port that needs to be drilled and a pipe inserted is on the actual upper intake? Do we just clean the bottom intake or is there something better we can do to it as well?
Any other tips to make it go smoothly.
Thanks.
Old Apr 18, 2013 | 10:48 AM
brian74d's Avatar
Exactly, you are only drilling / inserting the pipe in the upper intake manifold. I just cleaned mine (funds weren't available for the kit, so I just cleaned the ports). All went very well, just take your time and everything will be good.
Old Apr 18, 2013 | 09:49 PM
5.0stang's Avatar
Thanks Brian! Anybody else got any tips? It looks pretty straight forward.
I have installed h/c/i on 5.0L mustangs before, first time working on the Honda, outside of CV Axles.
Old Apr 18, 2013 | 10:08 PM
Take your time drilling. Line up the new pipe with the drill bit. Mark the bit with the length of the pipe. Then you will know when you drill through the bore and not through the other side.
Here is a video on how to remove the intake and clean the EGR port.
Old Apr 22, 2013 | 11:14 AM
5.0stang's Avatar
Did the EGR port fix, easy stuff.
Took me a second to figure it out, but make sure you mark the sleeve to the actual "drilling portion" of the drill bit, because the Honda piece comes with a guide before the actual "drilling portion", so you will think you drilled down deep enough, but the sleeve will stop.
Anyways, random question:
What does the sleeve need to be installed? You drill the hole out larger. My only thought is for it to provide a smooth path for the EGR gasses/junk to escape out, so there is no burs for any of it to catch on.
Old Apr 25, 2013 | 10:43 PM
5.0stang's Avatar
Why does the sleeve need to be installed? You drill the hole out larger. My only thought is for it to provide a smooth path for the EGR gasses/junk to escape out, so there is no burs for any of it to catch on.
Old Apr 27, 2013 | 08:08 AM
I'm not the engineer......could this be the metals involved?
Old Apr 27, 2013 | 08:35 AM
The reason for the sleeve is to get the correct amount of EG to flow to each port. Some ports are larger than others (those furtherest away). If ports are not correctly sized, you may get the infamous EGR stumble (too much EG to one port).
In this case, the sleeve is to port the correct total amount of EG. He did not clean the individual ports, which may be why the miss codes were occurring.
Old Apr 28, 2013 | 06:03 PM
5.0stang's Avatar
I'm still not sure I follow, even though what you are saying makes sense. The drillbit (which I did this last week) enlarges the hole all the way to the "bottom". The sleeve actually shrinks the available EGR passage way, although maybe by 5% or so if I had to guess. Hard to explain I guess.
Imagine a cylinder sleeve when you are rebuilding an engine, it is to have a "fresh" wall to work from. The sleeve is the same length as the cylinder, so why do we need a sleeve to be inserted into a hole the same size for EGR gas?
Old Apr 28, 2013 | 11:09 PM
My guess would be a smoother surface where the soot would not easily stick compared to just having cast iron there.
ccookie66
Mar 31, 2014 10:34 AM
jsmackle
Nov 15, 2012 08:45 PM
embpilot
Apr 9, 2009 06:29 PM
Tony1M
Jul 6, 2008 03:15 PM
Adie
Aug 20, 2006 09:28 AM
