Radiator fan won't engage when engine running
Old Aug 1, 2012 | 01:09 PM
doctorbee's Avatar
that sounds about right. it shouldn't go above halfway
Old Aug 1, 2012 | 04:20 PM
Cody_754's Avatar
Almost A Senior Member
Thanks guys much appreciated! I feel a lot better now knowing that's ok. For some reason I have it programmed in my head that the temp gauge should never get any hotter than 40%. I need to deal with it lol.
Old Aug 6, 2012 | 03:33 PM
Cody_754's Avatar
Well it's doing it again...cooling fan will not engage while engine in running causing it to overheat. I didn't want to think of it to much but when I was burping the cooling system of air last week little bubbles never stopped coming out of the radiator. I eventually just capped it off after the car was at operating temperature. Is a compression test or leak down test better for finding a head gasket issue? I don't know the differences between the two.
Old Aug 6, 2012 | 04:44 PM
I vote for leakdown test.
Compression test uses a pressure gauge stuck into the sparkplug hole. You crank the engine with the starter and see what the pressure reaches.
A simplified version of a leakdown test can go like this... Get a fitting for a compressed-air hose, that fits into the sparkplug hole. Rotate the engine so that cylinder is TDC of the compression stroke. THIS IS IMPORTANT - LOCK THE CRANKSHAFT so it won't spin on you when you pressurize it. With compressed air, you look & listen for WHERE the air is leaking.
- into the crankcase means rings are leaking (a bit of this is sorta normal)
- into the intake manifold or exhaust manifold means the valves are leaking
- into the water jacket means the headgasket is leaking (or cracked block)
A proper leakdown test can measure the actual flow rate, but you don't really need that to diagnose a leaking headgasket.
Old Aug 8, 2012 | 04:48 PM
Cody_754's Avatar
Head gasket going bad. Confirmed by a Honda specialized mechanic.
Old Aug 8, 2012 | 09:09 PM
Ok, you may not like this but I'm wondering if you might have a head gasket issue?
Can you do a compression test and or leak down test?
That sucks......So what are your plans?
Paullad
Aug 20, 2013 08:36 AM
Novaknowledgenow
May 30, 2013 08:58 PM
Rice
Apr 27, 2012 08:38 AM
aneelley
Apr 19, 2010 07:40 PM
rtmobile96
Sep 16, 2007 04:14 PM
