Radio Code
Old Nov 11, 2010 | 12:22 AM
wunderbra's Avatar
Default Radio Code
Bought a 97 with a working radio, but no code found. I know I will be changing battery or some other reason to de-power . Is there a way to pull the radio out enough to get the serial number without disconnecting the harness?
Old Nov 11, 2010 | 07:40 AM
Go to ahm-ownerlink dot com
Register with the car's VIN.
I'm pretty sure you can get the radio code there, as long as it's the original factory radio (hasn't ever been replaced).
Old Nov 11, 2010 | 05:50 PM
hondadude's Avatar
Also you can remove the ashtray and the ashtray holding bracket [3 phillips screws]
Then with a flash light and inspection mirror you'll be able to read the numbers on the label that is on the bottom of the radio case.
Then the Dealer Parts Dept. can get you the code.
Been There, Done That, Seen the Movie, & Got the T-shirt
Old Nov 13, 2010 | 01:31 PM
wunderbra's Avatar
Thanks!
Robert Bean
Mar 12, 2012 10:23 AM
usmrocks
Nov 28, 2010 09:32 AM
will'i'am
Sep 16, 2010 01:19 PM
Stener75
Jul 25, 2010 08:21 PM
madsteez
Jan 18, 2009 07:43 PM
