Radio Lights not on...
Old Oct 30, 2007 | 11:44 AM
04AccordEX's Avatar
Default Radio Lights not on...
My first post, i think.. like the forum!! will post up my pics soon.. I just purchased a used 04 Accord EX 4cyl manual with 50K. I turned the car on this morning, the dash lit up full (i have it on th brightest setting) but the radio lights did not come on at all... when i shine a flashlight, or suring the day when the sun hits it, i can read it, but it does not light up or move with the light dimmer switch. Any help would be greatly appreciated, cuz i cant tell what im doing in the dark, lol...
Old Oct 31, 2007 | 03:58 AM
2POINTautO's Avatar
Default RE: Radio Lights not on...
Wow, what a set up, never noticed such a large wire diagram for a sound system before, Illumination + B8 red / blk, Illumination - B12 brn, Interior lights dim + A9 red / blk, Interior lights dim - A19 red.
This is for the 2.4L version, it could also just be a problem inside the radio, do you have the code to reset the radio if you pull it out and disconnect power, is it an anti theft radio.
Old Oct 31, 2007 | 06:09 AM
04AccordEX's Avatar
yes it is an anti theft radio. dont know about a code.
BTW, thanks for replying!
Old Oct 31, 2007 | 07:26 PM
04AccordEX's Avatar
i checked the fuses, all good, undid the positive battery and put back together, nothing... took the dash apart and unplugged and replugged the radio harness, and nothing.....
Old Nov 1, 2007 | 12:33 PM
04AccordEX's Avatar
well i called the local honda stealersip and they said that this is a common problems with this model of accords, lady i work with has an 04 with 50K and she had the same exact problem at the same miles... lol...
the guy said they have to take the radio apart and replace a board inside the radio. I get a 30 day warranty with my purchase of my accord, since it was used... so, just another problem solved!!!
HOPEFULLY PEOPLE CAN FUND THIS IF THEY SEARCH!!! if someone has this proble.
Old Nov 1, 2007 | 12:45 PM
falkore24's Avatar
While you're at it, you should look up all of the TSB's and recalls to make sure that everything has been done.
Old Nov 1, 2007 | 01:02 PM
04AccordEX's Avatar
ORIGINAL: falkore24
how do i do that?
Old Nov 1, 2007 | 01:18 PM
04AccordEX's Avatar
https://www.hondaaccordforum.com/rec..._04027/TSB.htm
now what do i do with that? do i take it to a dealership?
Old Nov 2, 2007 | 01:25 AM
2POINTautO's Avatar
Not all TSBs are free to the car owner, Recalls are.
Old Nov 2, 2007 | 06:08 AM
04AccordEX's Avatar
ORIGINAL: 2POINTautO
understood!! im just glad this is covered under an extra warranty that was added to this car by the factory to the radio. He said some specific models have this extension on the factory warranty b/c of this defect. So if anyone ever has this problem, check and see if yours is covered, just cal the stealership and give em your VIN.
SPBAV6
Sep 27, 2013 09:47 AM
csh217
Apr 30, 2013 09:03 PM
Uberpippi
Feb 1, 2013 10:09 PM
naimperez
Oct 2, 2011 07:01 PM
rogerthat23
Apr 11, 2009 10:32 PM
