Radio will only work when the car is running
Old Apr 10, 2014 | 10:56 PM
45sz's Avatar
Default Radio will only work when the car is running
I have a 08 Honda Accord coupe v6 with Navigation
Recently, my radio will not work in accessory or ON mode , it will only work when the car is running. Even the Aux mode to my iPod will only work if the car is running.
Also, quite a few times I have had to enter the navigation system password , as if it was reset or something was disconnected.
Once the car is running, everything works as it should.
I just put a new battery in , thinking that was the problem but it did not help.
It is not a big deal, but rather annoying and I would like to know why ?
Normally you can listen to the radio without the car actually running...
Any ideas ?
Thanks !
Old Apr 11, 2014 | 12:25 AM
You may have a blown fuse. Check interior driver's side Fuse No. 18 (7.5A).
Old Apr 11, 2014 | 01:08 AM
45sz's Avatar
Thanks for the response. I checked it along with many others but they all look good. I checked practically every fuse in the fuse box under the hood as well, including the multi ones that needed a screwdriver...
After just playing around for 2 hours with it , it turns out the navigation system and radio are supposed to come on in accessory/ on mode(thought it was just radio... Never really paid attention to that). Now,once every few try's the nav system will come in but it flashes in and out like it's not getting enough juice to fully come on, as well as the radio at the same time. I checked all the fuses in all 3 box , anyone know if there is some kind of "accessory wire " for the radio / nav system that could be loose?
I don't understand because when the car is running everything works 100%
Old Apr 11, 2014 | 08:11 AM
Perhaps a failing ignition switch assy. Hondas are notorious for this problem.
Check purple wire w/ keyswitch in On position. If does not have 12V, the keyswitch is likely source of problem.
Old Apr 11, 2014 | 09:33 AM
Wiggle the key when you check that wire for voltage. Sounds like it's flaky, so if it happens to make good contact when you measure, you'll waste time looking for other causes.
Old Apr 11, 2014 | 10:35 PM
45sz's Avatar
Where exactly is this purple wire ? I don't really savvy much when it comes to cars / electrical stuff.
Would auto zone or advanced auto parts be able to check it ?
Thanks !
Old Apr 11, 2014 | 10:36 PM
45sz's Avatar
Thank you!
Old Apr 12, 2014 | 09:02 AM
Thanks !
Driver's under dash fuse box or passenger under dash fuse box. It should be visible in harness to these units. You will need a back probe pin to make contact.
It ultimately connects to audio unit, but you'll have to pull panel trim to access audio unit.
Old Apr 12, 2014 | 11:16 AM
Power for the purple wire comes through driver's Fuse 18 (7.5) with the ignition turned to ACC or ON. Therefore, you can just test for power at the fuse with the ignition turned to ACC or ON; without necessarily having to locate the purple wire to see if it may be related to the ignition switch.
Old Apr 13, 2014 | 05:21 AM
45sz's Avatar
Thank you!
I'll post back once I know
