Radio won't turn on
Hi everyone,
My 2006 EX-L Honda Accord Radio (with built-in xm satellite radio) does not work AT ALL. Absolutely NOTHING comes on when i put the keys in the ignition and turn the engine on. I am very very worried. This occurred as a result of me trying to install a GTA car kit for my iPod touch onto the auxillary outlet of the radio. I think I might have found the auxillary outlet under the radio, but it was blocked by a tightly fitted metal plate. I wanted to remove the radio, but the underlying two screws beneath the stereo were too tight for me to remove. So I tried to pry open the metal plate with a screwdriver, but then I saw a bright spark for a split second. I became worried and tried to turn on the stereo, and that's when I realized that I might have busted it. However, my A/C still works, but I see no display. Should I get a new fuse for the radio? Should I reset the radio fuse in the car's fuse box? I am very very concerned about this. Please help!!!!!!!!! Thank you!!! |
Did you just blow the radio fuse?
i dont know...My radio won't work. I also forgot to mention that its also a 6-CD changer player too.
stupid response perhaps, but did you punch-in the radio security code?
1 Attachment(s)
First step would be to check the fuse.
sparks are never good, if you are VEEERRYY lucky it's just a fuse, ....if not, well get out the wallet. i'm sure i've said this to a million people 2 million times...disconnect the battery when you do electrical work!
1 Attachment(s)
looks like this.
AC works just fine as indicated by the green and orange lights. display not coming up. radio not working CD not working. should i disconnect the cables from the battery and re-connect them? or should i open up the fuse box and remove/insert fuses? thanks |
Did you check the fuse that redbull suggested?
yes i did check the fuse box. but what exactly am i lookiing for? lol. do i remove the fuses with a pair of forceps/tweezers?
That fuse that is labeled in redbull's post is the one you need to pull. Use a small pair of needle nose pliers to pull it out.
You look at the metal wire inside to see if it burned out. Here is a pic of two blown fuses I found on the web. The one on the right is blown too. A good fuse will be a continuous piece of metal. http://1.bp.blogspot.com/_rHkzZmFpsi...0/DSCF4202.JPG |
