Radio won't turn on
Old Aug 18, 2012 | 12:02 AM
billyspvy's Avatar
Default Radio won't turn on
Hi everyone,
My 2006 EX-L Honda Accord Radio (with built-in xm satellite radio) does not work AT ALL.
Absolutely NOTHING comes on when i put the keys in the ignition and turn the engine on. I am very very worried. This occurred as a result of me trying to install a GTA car kit for my iPod touch onto the auxillary outlet of the radio.
I think I might have found the auxillary outlet under the radio, but it was blocked by a tightly fitted metal plate. I wanted to remove the radio, but the underlying two screws beneath the stereo were too tight for me to remove. So I tried to pry open the metal plate with a screwdriver, but then I saw a bright spark for a split second. I became worried and tried to turn on the stereo, and that's when I realized that I might have busted it.
However, my A/C still works, but I see no display.
Should I get a new fuse for the radio? Should I reset the radio fuse in the car's fuse box?
I am very very concerned about this. Please help!!!!!!!!! Thank you!!!
Old Aug 18, 2012 | 12:39 AM
Did you just blow the radio fuse?
Old Aug 18, 2012 | 01:24 AM
billyspvy's Avatar
i dont know...My radio won't work. I also forgot to mention that its also a 6-CD changer player too.
Old Aug 18, 2012 | 07:07 AM
fvansan's Avatar
stupid response perhaps, but did you punch-in the radio security code?
Old Aug 18, 2012 | 08:59 AM
First step would be to check the fuse.
Old Aug 18, 2012 | 10:16 AM
Dr. Drivability's Avatar
sparks are never good, if you are VEEERRYY lucky it's just a fuse, ....if not, well get out the wallet. i'm sure i've said this to a million people 2 million times...disconnect the battery when you do electrical work!
Old Aug 18, 2012 | 03:17 PM
billyspvy's Avatar
looks like this.
AC works just fine as indicated by the green and orange lights.
display not coming up.
radio not working
CD not working.
should i disconnect the cables from the battery and re-connect them?
or should i open up the fuse box and remove/insert fuses?
thanks
Old Aug 18, 2012 | 05:42 PM
Did you check the fuse that redbull suggested?
Old Aug 18, 2012 | 07:11 PM
billyspvy's Avatar
yes i did check the fuse box. but what exactly am i lookiing for? lol. do i remove the fuses with a pair of forceps/tweezers?
Old Aug 18, 2012 | 07:37 PM
That fuse that is labeled in redbull's post is the one you need to pull. Use a small pair of needle nose pliers to pull it out.
You look at the metal wire inside to see if it burned out.
Here is a pic of two blown fuses I found on the web. The one on the right is blown too. A good fuse will be a continuous piece of metal.
