Re: Alternator shot??
Old May 18, 2010 | 09:44 PM
grim_reaper's Avatar
Alright so I got a couple more pictures for you as to what could possibly be the spool valve.. I am really dumb. Anyway take a look at them pictures and see if I got it right this time in one of them.
Old May 19, 2010 | 02:00 AM
The top picture in your last post is it.
Old May 19, 2010 | 06:52 AM
I thought that was it since one of you guys said it was a triangular flange with a single wire going to it. But anyway, the single wire doesn't look corroded or cut or anything so I guess that's not the reason for the P1259 code??
Old May 19, 2010 | 07:05 AM
Above the triangle flange is the VTEC solenoid. The whole thing is called the spool valve assembly. Now that you've found the spool valve assembly, go back to the picture I put in post#5...
The VTEC oil-pressure switch is #14 sticking out to the side, down lower on the spool valve. Down off the lower-left of your first picture. THAT's the plug (2-wires) for you to check.
Old May 21, 2010 | 07:30 AM
Alright so I checked out that wire you suggested and there seems to be nothing wrong with them. They don't even look corroded or anything so I guess that isn't it??
Old May 21, 2010 | 07:51 AM
I guess the next thing would be remove the whole spool valve assembly from the head, & clean it out. Sludge clogging up the screen in the #13 gasket (in my earlier picture)?
Old May 22, 2010 | 07:55 AM
  #17
Alright I looked at your earlier picture. So I guess the screen would be inside the spool valve assembly right?? This shouldn't be too complicated for me to hopefully?? I'll give it a shot one of these. If I break my car then I declare myself awful at life. lol..
Old May 22, 2010 | 10:57 AM
  #18
The screen is sorta part of the gasket (#13) where it bolts against the head. Picture shows it like a separate part, but I've seen it molded into the gasket. On second thought, I'd buy a new gasket.
But if there's sludge, I'd clean out the entire spool valve assembly.
Old May 23, 2010 | 07:21 AM
  #19
Alright so I'll give it try and just take it apart. Just those three screw things so it shouldn't be a big deal..
aking
Apr 4, 2011 11:19 AM
kornbln
Aug 28, 2008 11:58 AM
reinventingaxlrose
Jan 25, 2008 01:29 PM
Alalbastersilver07
Oct 2, 2007 05:16 PM
blackex19
Aug 3, 2007 11:37 PM
