rear balancer shaft 92 accord
I'm trying to get the rear balancer shaft turned to it's correct rotational position before re-installing the balancer belt on my 92 Accord. My manual and other instructions I've seen online says to remove the access/maintenance bolt and insert a 6mm size bolt or rod in there while gradually slowly turning the rear balancer sprocket until the rod goes in to a specified 74mm distance. I'm finding that the rod actually goes in four different places as I turn the sprocket, and each time it actually inserts to about 80mm, not 74mm. Each insertion feels the same with the rod, I'm not forcing or doing anything unusual.
There's a V mark and also a dot mark on the rear balancer sprocket. I took note of the marks on the sprocket when I could get it in. They are:
V at 12 o'clock with dot at 5 o'clock
V at 9 o'clock with dot at 2 o'clock
V at 6 o'clock with dot at 11 o'clock
V at 3 o'clock with dot at 8 o'clock
Any comments/help appreciated.
Last edited by sgull; Jul 21, 2013 at 11:04 AM. Reason: correct my initial mistake of saying the last V position was 8 (changed to 3)
I think that the balance shaft turns 4 times for every time cylinder 1 goes to TDC. If you have the timing belt installed in time, you can install the balance shaft belt. Then turn the crankshaft two revolutions and count how many times the dot on the rear gear went around.
The dot on the gear is the moving mark. The stationary mark is around 5 o'clock on the casing. It was kind of hard to see on my accord.
I think that if you set the balance shaft with the drill bit, then you are good to go.
There is a post by tony1m on here that shows pictures of the timing marks that should also help.
I do have the timing belt installed in time. I was wanting to install the balancer belt on the front balancer sprocket (also in its correct rotational position at the same time, with groove on shaft aligned with engine block mark) while installing the belt on the rear sprocket also. So I'm wanting to install the balancer belt with both the front and rear sprockets in their proper positions while at #1 TDC. Isn't there a sure-fire way to know which of the positions of the rear sprocket I listed here on my initial post is the right one in advance of having to turn the crankshaft? ( I did use a 6mm diameter drill bit pushed into the hole to 80mm in all the four positions I mentioned).
I think there's a gearset (not 1:1 ratio) at the sprocket for the rear balancer shaft. So you line up that rear shaft by putting a pin through a hole in the back of the engine block, and ignore the marks on the actual sprocket. Those marks are for when you replace the sprocket and gearset.
Oh heck here I go off the deep end again.
Might need a helper but pretty sure you can do this yourself......using the "pin/bit" put it in there and find the "shaft", then a slightly move it to the bottom part of the shaft. Spin the shaft counter clockwise slowly while hold light pressure on the "pin/bit", at some point the "lobe/hole" of the shaft will come around and try to push the pin/bit back.
Lower the angle on the bit and see if goes in....might need to move the shaft a tiny bit. Once it "goes in".....veryify the shaft is "locked" by the pin/bit.
I know Tony sent you a pic showing how the "lock hole" in the shaft is. So with that and what I'm trying to describe I think you might understand where I'm going with this.
Did you get the "washer" for the tensioner?
using the "pin/bit" put it in there and find the "shaft", then a slightly move it to the bottom part of the shaft. Spin the shaft counter clockwise slowly while hold light pressure on the "pin/bit", at some point the "lobe/hole" of the shaft will come around and try to push the pin/bit back. Lower the angle on the bit and see if goes in....might need to move the shaft a tiny bit. Once it "goes in".....veryify the shaft is "locked" by the pin/bit. I know Tony sent you a pic showing how the "lock hole" in the shaft is. So with that and what I'm trying to describe I think you might understand where I'm going with this. Did you get the "washer" for the tensioner?
Last edited by sgull; Jul 20, 2013 at 01:23 PM. Reason: change typo from "10mm" to 6mm
