Rear brake locking up
Old Aug 28, 2007 | 05:33 PM
swordfish7769's Avatar
Default Rear brake locking up
I just recently replaced the pads and rotors on my 97 EX. Now when I apply the parking brake the right rear caliper will stay engaged. I have to physically go to the rear of the car and pull the arm on the caliper towards the rear of the car. Once I do that the brake is fine and it does not drag until I apply the E-brake again. This all started when I was parked on an incline and I set the parking brake cause I didn't want all that load on the tranny itself. I pulled the handle up farther then I had in the past. Ever since then it locks when applied. Would this be a caliper issue, a cable sticking issue. What could the problem be? I thought about replacing the caliper, but I figured I would ask first just in case it was something easy. Thanks for the help
swordfish
Old Aug 28, 2007 | 06:07 PM
sir_nasty's Avatar
Default RE: Rear brake locking up
Sounds like a return spring issue.... look at the opposite side of the car and inspect the spring on it, make sure that the tension feels the same and that it's present on the side that is having the issue.
Old Aug 29, 2007 | 12:20 AM
Unhook the cables from the calipers. Work the handbrake lever on the caliper to see whether one has more friction than the other. Then push/pull the cable on both sides. You'll have to figure out whether it's rusty/sticky/dirty in the cable or in the caliper. Either one (or both) are possible. It's also possible for one or both springs to get weak from heat.
Old Aug 29, 2007 | 11:57 AM
deserthonda's Avatar
i second Jim advice to disconnect the cables from the calipers to properly diagnose if it is a brake cable or caliper issue
Old Aug 30, 2007 | 06:08 AM
Thanks Guys! I will be checking it out this weekend, as well as doing some other stuff I discovered on here. Great site...keep up the good work.
swordfish
francy21
Aug 25, 2012 11:21 AM
Fat Ryan
Jun 23, 2009 01:26 PM
andy 95
Aug 14, 2007 11:58 AM
Data7
Jun 8, 2006 05:31 PM
kpearson10
Aug 23, 2005 02:34 PM
