Rear counterbalnce shaft alignment
Old Oct 17, 2010 | 09:46 AM
Hal Murdoch's Avatar
Default Rear counterbalnce shaft alignment
I have a 1998 Honda Accord LX 4 cyl in which I'm replacing the water pump and timing belt etc. I need to know which marks on the rear counterbalance shaft sprocket indicate the correct alignment. I have tried inserting a 6 mm. pin in the access hole in the rear of the block, but there seem to be multiple positions where it can be inserted. Since there are multiple marks on the the sprocket, I am unsure which one is correct.
Thank you for any advice you may offer.
Hal Murdoch
hal @lnf.com
MGF 1996 Accord
Jan 7, 2015 03:31 PM
ocoF23A1
Feb 26, 2014 10:05 PM
Afnan
Nov 19, 2013 05:52 PM
hondaed720
Sep 6, 2011 06:48 PM
rschmitt2
Jan 6, 2007 08:31 PM
