REAR ENGINE MOUNT
Old Aug 7, 2006 | 09:46 PM
collierville's Avatar
Default REAR ENGINE MOUNT
CAN SOME ONE GIVE ME A QUICK REMOVE AND REPLACEMENT OF THE REAR ENGINE MOUNT ON A 93 ACCORD EX 4-DR AUTO. LIKE WHAT NEEDS TO COME OFF TO GET THE MOUNT.... THX KEN
Old Aug 8, 2006 | 04:35 AM
deserthonda's Avatar
Default RE: REAR ENGINE MOUNT
ORIGINAL: collierville
Hello KEN.......
I can tell you the way i do it,, but i have all the necessary tools and equipments to make the job easier......
First off i remove the mount from the bottom of the car.
#1 from under the hood, remove the 17mm bolts that goes through the mount
# 2 remove 2 of the 14mm bolts that hold the mount to the rear beam, you need a long extension,
raise the car up....
remove the left axle ,, there is a write up on our DIY section HOW TO REPLACE AXLE
remove the vacc hose that goes to the rear mount
you need to support the engine.,, remove the 17 mm bolts that hold the rear mount bracket to tranny,
remove the l;ast 14mm bolt that hold the mount to rear beam.
push back on the mount toward the rear of the beam,
pull out the bracket, you might have to pry a bit , to make it go over the tranny part
remove the rear mount
when installing the new mount, lay it up on the rear beam, push it as far back as you can.
install the mount bracket, do not install any bolts at this time for the bracket to tranny till you have centered the mount into it , once the bracket is slipped over the mount.
install the 3, 14 mm bolts that hold the mount to the rear beam
install the 17mm bolts that hold the bracket to tranny .. you might have to raise or lower engine a bit to make it line up properly...ALWAYS START bolts by hand to make sure you DO NOT cross thread them. ,,
the rtest should be pretty easy,,,,,,Oh do not forget to reconnect the vacc hose to the mount diaphram..
If someone has a different , easier way,, please let him know ..
Old Aug 8, 2006 | 04:43 AM
YeuEmMaiMai's Avatar
I got an easier way....
let someone else do it :P
DH where you been lately?
Old Aug 8, 2006 | 04:54 AM
ehy YEU,,
MMMM ??? what do you mean were have i been ?? i have been here my friend ,,
Old Aug 8, 2006 | 11:37 AM
DH THX'S,
THIS SHOULD NOT BE A PROBLEM, JUST NEEDED A LITTLE HELP THE THE BOYS IN THE KNOW.
HOW LONG SHOULD THIS TAKE AVERAGE PERSON WITH GOOD TOOLS ?
TRYIN TO FIT IT IN AROUND OTHER PROJECTS......KEN
Old Aug 8, 2006 | 01:01 PM
incountry's Avatar
the last one I did was on a lift and with a honda mechanic and myself it took about 2 hours give or take, it is a very tedious job, not one of my favorites
Old Aug 8, 2006 | 01:11 PM
THX'S INCOUNTRY,
SHOULD TAKE A LITTLE LONGER WITH NO LIFT, JUST FLOOR JACK AND STANDS...KEN
Old Aug 9, 2006 | 11:07 PM
I AM TRYING TO GET THE LAST BOLT (14 MM) OUT THE REAR MOUNT UNDER THE THROTTLE BODY. CAN ANYBODY HELP... THX KEN
Old Aug 11, 2006 | 01:21 AM
I WAS ABLE TO GET OUT THAT LAST BOLT, AND SWAPED OUT REAR MOUNT. NOT THAT BAD OF A JOB. WILL BE MUCH QUICKER ON THE NEXT ONE.. ALMOST ALL OF THE VIBRATION IS NOW GONE IN THE STEERING WHEEL. HAVE ONE MOUNT LEFT TO DO ... THX FOR THE HELP...KEN
Old Sep 3, 2015 | 10:56 PM
tashier's Avatar
Good thread.
tizzo
Aug 21, 2010 08:06 PM
Mr_Accord
Mar 19, 2010 07:34 AM
baer77
Feb 27, 2009 03:47 PM
ranma21
Oct 21, 2008 12:24 AM
Mpwr
May 30, 2006 11:18 PM
