Rear Rotor stuck
Old Apr 13, 2013 | 01:38 PM
agawam's Avatar
Default Rear Rotor stuck
While replacing the rear brake pads and rotors on my 04 accord, I found the two screws on the rotor to be frozen. I have tried PB blaster, also heat ,neither has helped. Next I tried a impact screw driver on . Not turning.Corvettes have their rotors riveted on , and the procedure is to just drill them out and to leave them off, as the they were only need in assembly Next I plan to do the and just drill off the heads remove the rotors then try to remove the stud with a pair of vise-grips, and if that fails I'll just grind them flush to the hub. Anyone see any problems with this plan????? Commits Please if there is something I missed or forgot . Please let me know
Old Apr 13, 2013 | 03:00 PM
I drilled out the heads on my old rotors. Tried the vice grips, didn't work, so I drilled out the old bolt.
Try what is on this video first and let us know if it works:
Old Apr 13, 2013 | 06:47 PM
EXV6NIGHTHAWK's Avatar
I tried the impact driver, even after soaking in PB blaster for a day, and the hammer trick too, and neither worked. After drilling off the heads, the studs came out without a problem. Should have done that first, it seems.
Old Apr 14, 2013 | 12:18 PM
agawam's Avatar
Default Success
+After trying everything including the hammer thing. I found my old punches that I made in school many years ago in shop class. What I did was drill a 1/8 th inch hole may1/16 deep and then used the punch at a angle and it just about Jumped out, did all 4 in under 15 min. Happy Happy Happy Thanks for all the help and the vidio
Old Apr 14, 2013 | 12:47 PM
A good ending to a story....thanks for coming back with what/how it turned out.
Old Apr 14, 2013 | 01:43 PM
RobinsonRicer's Avatar
i had to use a metal cutter when my impact driver broke on the screws. I went to town on that thing.
Old Apr 14, 2013 | 08:40 PM
In situations like this, you find out how determined you are, to get the job done. Some will just give up, and take it to the shop. That's not us, right?
Old Apr 15, 2013 | 07:21 AM
Nope, cuz then you cant throw the disfigured rotor that you viciously cut off and beat your chest like an ape in a victory dance.
cukaracha
Apr 22, 2015 09:29 PM
bkraz
May 1, 2012 12:42 PM
Wicked Pete
May 15, 2010 04:36 PM
respectmyfresh
Mar 31, 2009 01:51 PM
German IV Ever
Mar 29, 2008 09:55 AM
