Rear sag
Old May 12, 2012 | 04:14 PM
accordmike's Avatar
Default Rear sag
Hi everyone. I moved out of my dorm yesterday and had quite a bit in the trunk and backseat. I noticed when I was about to head home that the rear was much, much lower than usual. It looked uncomfortable to me but there wasn't anything I could do about it.
Now that I have everything out of my car, the rear is still noticeably lower than before moving. (but rose once the stuff was taken out)
I drive modestly, I never have anything in my car, ever, and the rear used to be a few inches higher looking than the front. They look about even now.
Do I have problems with my springs? Is there a way to take it in somewhere and just have them tighten or adjust them so it rides at the same height as before the move? Would tire pressure make a difference - and could that be affected in the move?
Thanks for your help!
Edit: I guess this would be useful: 2002 Accord EX Sedan 113k
Old May 12, 2012 | 06:05 PM
The stock springs can not be adjusted. Now if you had aftermarket coil-over setup, then you can adjust the height.
check to see if your springs are cracked
jza240sx
Apr 30, 2013 04:14 PM
SC Tiger
Jul 11, 2011 09:15 PM
