rear view mirror removal
Old Apr 14, 2007 | 05:42 PM
trukid21's Avatar
Default rear view mirror removal
how do you remove the rear view mirror? i plan to replace mine with a wider mirror so i can see the blind side area on my car. the manuals i have do not say anything of how to, so i figured you guys could help. Thanks.
Old Apr 14, 2007 | 09:25 PM
Chiovnidca's Avatar
Default RE: rear view mirror removal
Remove the cover, remove the screws.
Old Apr 14, 2007 | 09:41 PM
You may mean "how do you remove the anchor adhesively attached to window?" Good question.
A quick google search didn't reveal any immediate answers. You may want to try additional searches using keywords "auto mirror adhesive removal". This is your best bet to find some experience w/ this problem.
If you don't find any experienced advice, I would suggest trying removal by slowwwwly warming the bonded anchor plate w/ a heat gun. Too much heat may cause the window itself to crack from thermal expansion. But 150-250 F warming plus a little prying may get the job done. Try gradually warming and gentle prying till it lifts.
Old Apr 14, 2007 | 11:59 PM
The 96 mirror is screwed into the roof.
They don't have the adhesive on the windshield.
Follow Chiovnidca's advice
Old Apr 15, 2007 | 02:56 AM
trukid21's Avatar
thanks guys, but i found a wider mirror clip-on from an autoparts store thas was reasonably cheap.so ibought it,it works wellthanks again.
Domindart
Jun 8, 2010 02:47 AM
Mikebike125
Mar 2, 2010 01:05 PM
unspokenadvocate
Oct 15, 2008 12:54 PM
Namedname
Jan 26, 2008 01:22 AM
02BlueAccord
Jan 26, 2007 12:55 PM
