Recharge Air Conditioner 94' & 06' Accord
Old Jul 21, 2009 | 10:10 AM
piper09
Default Recharge Air Conditioner 94' & 06' Accord
What is the pressure amount needed to recharge the air conditioner for a 94' & 06' Accord? Or is this needed?
Thanks
Old Jul 21, 2009 | 12:28 PM
You don't charge by pressure when system is empty. You recharge by vacuuming system, and then introducing the specification amount (weight in oz) of R134a into system. On Accords, 2-14oz cans is usually more than adequate (check under hood for specification amount).
If you're trying to "top-up" a working AC system, it is complicated and requires some experience to get close. A R134a AC manifold gauge set is required to monitor both high side and low side pressures w/ AC On, Max Fan, Recirculate, and engine at 1500-2000 rpm. Car should be in shade. You will also need to measure the air temperature entering the condensor at the front of the vehicle. Allow system to stablize for 5-10 mins. If fully charged the high side pressure should be 2.2-2.5 times air temp (in psi) entering condensor (when compressor is engaged), and low side pressure should about 24-30 psi. So at 100F air temp, pressure should be 220-250 psi high side and low side, 24-28 psi. Vent temps should be 35-45 below cabin air temp (on floor board). Extra charge is introduced through the low side slowly, allowing ac system to stabilize (1-2 mins) before adding more.
Suggest reading an automotive AC repair manual to provide some background and guidance to ac repair. Not difficult, but does require patience and determination.
Old Jul 21, 2009 | 04:18 PM
deserthonda's Avatar
Make sure to find out exactly how much freon you car takes if label is not on car .. do not just put in 2, 14 oz cans, some of these only take 22 oz max ,,,,,,and you do not want to overcharge the system
meazz1
Dec 15, 2017 07:35 PM
Fuller
Jan 16, 2015 07:49 PM
drumdoctor
Jan 16, 2012 09:53 AM
jbraly
Sep 1, 2009 01:26 PM
jeremiah6120
Apr 16, 2006 03:32 AM
