Remove center console
Old Sep 18, 2007 | 03:24 PM
dacecil's Avatar
Default Remove center console
Hey all,
How do I remove the center console in a 99 Accord EX V-6. I have taken out the four screws in the back and also pulled the cup holder and shifter handle. I have also removed the bezel around the gear selector. It still feels anchored. I'm sure there's just another plastic piece to be removed so I can access screws. But, if I don't get it right, I break off tabs and then everything is loose from here on.
Thanks,
Dale
Old Sep 18, 2007 | 03:56 PM
Default RE: Remove center console
Try hondaautomotiveparts.com, put in your car's particulars & look under 'console' or something like that. It'll probably help to have a parts drawing.
You mighthave to remove the lower panels on either side (under steering column & under glovebox). There's a couple hidden screws there. Also I think you have to pull up the bottom of the storage box for another pair of screws. It's been awhile since it did this...
Then again... I understand there's a Helm manual in the for-sale board...(j/k)
Old Sep 18, 2007 | 04:21 PM
00AccordLX5spd's Avatar
Registered User
This is in the DIY section:
https://www.hondaaccordforum.com/Gre...m_41104/tm.htm
Click on the first link in dh's post and follow his instructions on logging in. This site takes you to an exact copy of a Chilton Manual for almost any type of car. It shows how to remove the consolefor your car.
Old Sep 18, 2007 | 04:26 PM
Registered User
ORIGINAL: JimBlake
I've been trying to pimp your Helm over on 6thgenaccord.com. I guess you must not have gotten any bites yet.
haha! Post #1000! I'm such a
Old Sep 19, 2007 | 10:07 AM
Registered User
OK so I got bored last night and looked at my Haynes. I read what you already did, so I hope this explains the rest of the procedure. There are 4 screws inside the console itself. I don't know if you meant those were the ones you removed already or not. There are also 4 screws (2 on either side) at the front of the console (past the gear shifter) close to the floor. All must come out to remove the console.
accordlover9696
Oct 1, 2012 07:30 AM
ltdanp21
Jul 12, 2011 09:15 AM
MALSR
Nov 2, 2006 11:49 AM
johnc
Mar 6, 2006 05:14 PM
itsmetinh
Jan 1, 2006 11:42 PM
