removing lower balljoint
Old Jun 5, 2011 | 09:16 PM
Tek310's Avatar
Default removing lower balljoint
is there a way to remove and install lower ball joints without a ball joint puller or balljoint press?
Old Jun 6, 2011 | 12:43 AM
Lightbulb Hello Member
I hope this short video will help you get your job done for you..
Thanks for joining the HAF..A vety good forum...
click the link !
YouTube - ‪Tutorial: How to change a lower ball joint in a 1995 Honda Accord‬‏
Old Jun 6, 2011 | 01:28 AM
Here is another video showing a similar method. You wouldn't have to remove the rotor/hub/bearing on your car. Also, you don't have to remove the cv joint from the transmission. You will have to remove the axle nut to remove the knuckle.
YouTube - ‪Oops, Axle and Ball Joint Replacement‬‏
Old Jun 6, 2011 | 12:30 PM
Tek310's Avatar
awesome vids!! thanks a bunch!
Old Jun 6, 2011 | 03:13 PM
Tek310's Avatar
what is the socket size for the axle nut?
Old Jun 6, 2011 | 03:25 PM
It is 36mm
Old Jun 6, 2011 | 03:37 PM
Tek310's Avatar
thank you.
also upon removing one of my upper control arms i notice my ball joint is loose on it. you can wiggle it.
my other is actually tack welded to the arm so it can not be removed. is this a safety hazard? it has the c clamp ring on it and thats what is keeping it from coming out. when its bolted to the steering knuckle is it fine?
Old Jun 6, 2011 | 08:11 PM
Tek310's Avatar
The problem control arm
The one that is welded and secure
Old Jun 7, 2011 | 01:11 AM
Those ball joints are not really replaceable on the upper control arm, unlike the lower ball joint. Not sure about why the weld was done on the upper arm.
Your best bet is to get an aftermarket upper control arm to properly fix it.
bamaccord
May 22, 2009 03:41 PM
19Accord97
Apr 6, 2009 09:37 PM
desi01
Dec 30, 2006 07:16 PM
VT zog
Jun 19, 2006 03:35 AM
