replace knock senor wire harness how 2000 honda accord se
How do you replace the knock sensor wire harness on a 2000 honda accord se. Its a 4 cyl and has 200000 miles. I already know that its under the intake manifold. But what are the next steps. This is my first time working on my car.
First, please do not post in the DIY section.
How are you sure it is the wire, is the end bad?
Next, if you need to replace it. Once you have a new/used connector simply solder the wire and use heat shrink around the join. I would not use a butt connector on something like the knock sensor.....but that is me.
