Replace suspension parts in pairs?
Hey folks, my '02 has a clunking/popping noise coming from the front end at low speeds when turning or going over uneven roads. It's getting looked at by my mechanic on Friday. Is the consensus that when replacing older suspension parts, you do it in pairs, even if only one side was bad? The car has 110k on it, and this is the first vehicle I have owned that has had suspension/front end issues. Are the 6th gen accords prone to suspension issues? Cheap to fix??
Thanx
Thanx
For me, it depends on the part. I would inspect the part on the other side to see if it showing signs of wear. If I am doubt, I replace it.
Bigdawg - The anti-sway bar end links sound like a possibility from your description. Maybe the bushings on that bar. It could also be other suspension components. See what your mechanic says.
Ronjr - Your description of the 93 sounds like a possible CV joint problem.
NorthCountry
Sep 13, 2011 08:34 AM
faosh
Aug 7, 2007 06:25 AM
George Knighton
Jan 11, 2006 08:49 PM
