replaced head gasket, still overheating!
[QUOTE=STXHonda;179441
The radiator fan comes on as soon as the engine reaches normal operating temp, then it cycles on and off periodically. The condenser fan ( passenger side i believe but not sure) comes on as soon as you switch on the A/C or when the radiator overtemps.
Under normal conditions and with the A/C off only the radiator fan should be coming on.
Hope that helps.
New here, by the way.[/QUOTE]
First off Welcome to our little corner of the NET..
let me correct you..hope you do not get offended ,, but i want the correct info to be spread around our forum ....
..Main cooling fan is on the passenger side,,,,,,a/c condensor fan on driver side..........When engine reaches normal temp. t-stat opened BOTH FANS should come on, and both fans cycle according to coolant temp........if only 1 fan or neither fan come on, you got an issue
With the a/c engaged BOTH fans should come on and cycle on and off ..again if only 1 or neither fan come on there is a problem ...
Now on this overheating issue........
First off make sure that cooling system is bled properly, make sure that t-stat opens fully,, lower rad hose as hot as top hose, BOTH fans come on when coolant reaches the pre-set temp. ( about 1/2 to 5/8 on the gauge ).......
if all these work properly and engine overheats ,, since rad and cap are new and assuming in proper working condition,,,,,,,,DO A LEAKAGE TEST ,, it would tell you if you got a blown head gasket.......
Now.......if lower hose is not hot,,,,,,,,,,,,t-stat is stuck closed
if t-stat opens and fans do not come on,,jump the switch at t-stat housing ( make sure to have a good connection ), if both fans come on you got a bad switch
if fans do not come on,, it need to be diagnosed,,,,,,,fuses? relay? wiring ? motor?
i have only seen 1 water pump so badly corroded fins that it caused an issue ,, although possible i would be very surprised that the pump fins are all corroded to cause this simptom
there is a good trouble shooting guide on the DIY section .......( ...member take a look great info site ) ..
click on the link.. go to trouble shooting and go to overheating........
Hope that helps.
update;
i finally got my car back, with the second head gasket job done free of charge.
its running cool and so far no engine problems.
is there anything special i should do maintenance wise?
i am hoping this car will now last a long time!
tiresthatgrip
Aug 10, 2011 05:32 PM
chevmechanic
Apr 10, 2011 09:31 AM
