Replacing the Brake Light Switch on a 2000 Accord
Old Oct 4, 2009 | 12:05 PM
quigs72
Default Replacing the Brake Light Switch on a 2000 Accord
Hi all:
I recently had to replace my brake light switch (the brake lights didn't work and the shifter was stuck in park). After replacing it I noticed that the brake petal was slightly depressed when driving it, so I obviously did something wrong.
When I replaced it, I screwed it all the way in until it wouldn't go any more. I just went out a loosened it a bit and it seems to work fine now. However, there has to be a better way to know I installed this correctly.
Any advice?
Old Oct 4, 2009 | 09:19 PM
hondadude's Avatar
you should just screw the switch thru until the switch plunger [resting on the pedal arm] goes flush to the end of the switch 'neck'.
rudeg
Dec 31, 2015 07:23 PM
Jo_
Oct 1, 2012 12:56 PM
Rabbit
Sep 14, 2012 02:27 PM
victorywhity
Mar 24, 2011 09:37 PM
jdelgado
Oct 29, 2007 09:49 PM
