Replacing the ECU in a 96 Accord
Old Mar 30, 2012 | 10:13 AM
Lbrown85's Avatar
Default Replacing the ECU in a 96 Accord
The ECU in my 96 Accord is giving me a code for a part my car does not have. So, my check engine light will not go off without replacing my computer. I have read that many ECU's have immobilizers and would need to be reprogrammed by a Honda dealer.
If I buy a used ECU for a 96 Accord will it need to be reprogrammed? How much will it cost to have it reprogrammed?
Thanks for your help!
Old Mar 30, 2012 | 10:23 AM
crispin's Avatar
it will only need to be reprogrammed if you have the anti-theft key system for your car.
Do you have that?
Also what code is it giving?
Old Mar 30, 2012 | 11:43 AM
Before replacing ECU, suggest resetting ECU (pull BackUp fuse in underhood fuse box for 20 secs) and see if same code returns.
Poor power supply (bad alternator) can sometimes cause unusual codes to display.
Share the code number (Pnnnn) not the code name.
Old Mar 30, 2012 | 12:54 PM
Lbrown85's Avatar
The code is P0715
I tried unhooking the battery to reset the ECU, should I still try pulling the fuse?
I do not have a chip in my key for any anti-theft system.
Old Mar 30, 2012 | 12:58 PM
crispin's Avatar
Originally Posted by Lbrown85
The code is P0715
So then you will not have to get the ECU reprogrammed.
Old Mar 30, 2012 | 01:02 PM
crispin's Avatar
P0715 is for transmission speed sensor
http://engine-codes.com/p0715_honda.html
How does the transmission shift?
When is the last time the trans fluid was drained and filled with Honda Z-1?
Old Mar 30, 2012 | 02:12 PM
Lbrown85's Avatar
Sorry the code is actually P1108
I just replaced the old fluid with the Honda Z-1 because my transmission started failing. That is when the P0715 came up...which I have read most likely means my transmission is shot. I wanted to make sure my ECU was working properly before I replaced the old transmission though.
Old Mar 30, 2012 | 03:18 PM
crispin's Avatar
That code is
P1108 Barometric Pressure (BARO) Sensor Circuit High Voltage
Someone else will have to chime in as I do not know what that is.
Old Mar 30, 2012 | 03:22 PM
P0715 is a code that can be readily fixed. It's an electrical fault in the mainshaft speed sensor; connector, wiring, or possibly TCU.
On 94 Accord, the code for MSS is obd1 code 15 which advises to first check sensor resistance (400-600 ohms). If out of spec replace sensor. If ok, the connector, wiring, or TCU is the problem.
Code 1108 is a valid code for OBD2 Honda's and likely yours also. It's a barometric pressure sensor fault. The sensor is built into the ECU, so ECU should be replaced if this code persists. Check ebay and car-part.com for a used unit. Probably < $50.
Old Mar 30, 2012 | 04:43 PM
crispin's Avatar
I have an ECU here that will work for you.
It is from a 97 2.2 non-vtech automatic
$35 shipped
PM me if interested.
live2rice
Sep 20, 2012 02:26 PM
Julian91
Jan 21, 2007 03:54 AM
rupash88
May 3, 2006 01:53 PM
jasoncook3
Dec 28, 2005 10:10 PM
adbraz
May 31, 2005 12:03 AM
