95 dx 40 degrees advanced?
Old Mar 26, 2012 | 04:49 PM
Vw1302's Avatar
Default 95 dx 40 degrees advanced?
the car runs great i just put a new timing cover and harmonic balancer and with my timing light i can only see the marks where they should be at 40 degrees advanced. and i off a tooth ? it run perfect but i need the smog people to see the marks
Old Mar 27, 2012 | 06:02 PM
Is the service connector jumped while doing this?
Old Mar 29, 2012 | 01:03 PM
Vw1302's Avatar
i retimed the engine with service connector jumped and the only way the car runs good is at full retard on the dizzy.if i move it to full advance (were the timing marks match up ) it bogs with no power. am i a tooth off and if i am does that mean i need to turn the cam one tooth clock wise to fix this problem
Old Mar 30, 2012 | 06:22 PM
Time to pull the covers and check the marks....was the belt recently replaced?
dhansen
Jan 7, 2014 01:57 PM
gogy913
Dec 13, 2011 11:48 PM
Paralyse
Mar 15, 2008 10:29 PM
blown alcohol
Mar 3, 2008 06:46 AM
RoKnAzn
Jan 19, 2007 01:56 PM
