Replacing headlight bulbs
Old May 9, 2007 | 01:54 PM
vtecluder617's Avatar
Default Replacing headlight bulbs
Is it me, or is changing the bulbs abig pain in the a**? I cant seem to get the round bracket that holds the light bulb to turn. Is there a trick to doing it? Any info or help would be appreciated. I didnt think it would take this much work to change a light bulb.[:@]
Old May 9, 2007 | 02:01 PM
Default RE: Replacing headlight bulbs
and do you think wd-40 would loosen it up a little mabye??
Old May 9, 2007 | 02:02 PM
sir_nasty's Avatar
You're not the first person to have that issue..... some people have taken a long screwdriver and put it against one of the fins then lightly tap on that handle of it with a hammer or rock or something to break it loose....
Old May 9, 2007 | 03:13 PM
thanks for the info, im gonna go and try that now. do you think a little wd-40 would be smart to sprayt around it? or is it to risky cause of the wiring? thanks
Old May 9, 2007 | 03:31 PM
sir_nasty's Avatar
if the bulbs already burned out then some wD-40 probably wouldn't hurt anything....
Old May 9, 2007 | 05:49 PM
I did exactly what you said and it worked like a charm. didnt even use the wd-40. Thanks a bunch sir nasty!
Old May 9, 2007 | 06:15 PM
sir_nasty's Avatar
no problem! glad it worked for you
trijoon
Nov 20, 2010 11:34 AM
jbrams
May 11, 2010 10:30 AM
Darkangelo4o8
Aug 18, 2007 01:02 AM
rupash88
May 3, 2006 01:53 PM
05accord
Dec 2, 2005 09:22 AM
