Replacing my rear subframe
I have a 2000 handa accord dx 2.4l 4 Cy manual. I need to replace my rear subframe and while I'm at it I'm going to replace my fuel tank since I can't fill it over half way full. I'm pretty sure I have the right part ( rear sub frame) I need picked out. But I was just wondering if anyone with a bit more knowledge would link me what they belive is the correct sub frame for my 2000 accord.
I just did a quick search on hondapartsnow.com. Looks like 2 part numbers would fit your accord, but you should enter your vehicle info (2 vs 4 door may be different).
used parts sites like car-part.com should list vehicles/parts that can be used on your accord.
For the tank, you might have a pressure relief problem, where the tank's pressure increasing when adding gas, but can relive, so the gas station pump shuts off? You could swap the tank and still have the same problem if you put a faulty component from the old tank to the new tank.
The other item could be the fuel gauge is reading incorrectly, where E on your gauge is only half full?
swegyptian
May 17, 2011 12:42 PM
