Replacing Power Steering Pump--necessary to replace reservoir too?
Old May 31, 2013 | 02:35 PM
divinations's Avatar
Default Replacing Power Steering Pump--necessary to replace reservoir too?
Hello all, first post here.
I have a 2005 Accord v6 that needs a power steering pump replacement. The power steering is weak to nonexistent at low RPMs, but generally works OK when in motion. This basically is only noticeable when parking. I have taken it in to the local Honda dealer, had the recalled hose replaced, and replaced the O ring myself. The consensus I've gotten is that the pump needs to be replaced.
I have purchased the part already, and plan to have it installed by a mechanic this week. My question is, is it necessary (or how important is it) to replace the reservoir as well? I do not currently have this part. It seemed like there was a tiny bit of dirt/grit in it, but not much.
Any thoughts on this? I'm not much of a car guy as you can probably tell by my post.
Thanks in advance!
Tom
Old May 31, 2013 | 07:52 PM
Welcome to HAF Tom.
No the res should be fine. At most you might clean it out, a few different options. Be sure to only use Honda/Acura approved ps fluid. Honda's are picky when it comes to ps fluid (and a few others like auto trans fluid).
PGRNPA
Sep 29, 2013 09:30 AM
MessAround
Nov 4, 2012 06:51 PM
inthedump
Oct 28, 2009 09:35 PM
iridebmx33
Nov 26, 2007 06:53 PM
Tony1M
Sep 4, 2006 08:52 PM
