91 Accord Power Steering Fluid Leak out the top of the reservoir???
Old Nov 19, 2007 | 02:58 PM
iridebmx33's Avatar
Default 91 Accord Power Steering Fluid Leak out the top of the reservoir???
I drive a 1991 Honda Accord 2 Dr EX. Recently I noticed a spot under my car after I pulled it out the garage. I just thought that it was some oil, since my car leaked a little at times. Yesterday I did an oil change and noticed that around the top of the power steering reservoir was all wet with power steering fluid. I did some further inspections and found that it was running all down the side of the reservoir, inside the engine compartment and down onto my garage floor. Has anyone every heard of this happening? I though power steering parts leaked from hoses, not out the top through the tight fitting cap? I'm clueless on this one? If anyone has any help on this one it would be much appreciated! Thanks!
Old Nov 19, 2007 | 03:04 PM
sir_nasty's Avatar
Default RE: 91 Accord Power Steering Fluid Leak out the top of the reservoir???
Air leak? read the thread below
https://www.hondaaccordforum.com/m_38771/tm.htm
Old Nov 19, 2007 | 03:21 PM
iridebmx33's Avatar
Thanks man...I'll give it a look!
Old Nov 23, 2007 | 01:29 PM
iridebmx33's Avatar
So, I ended up getting some time to do a little more investigating on my power steering problem. I found that all the hoses were in great shape. What I did find was on the inside of the power steering pulley was wet with fluid. Since that seal is broke is it easy to replace or do I need to just replace the whole pump? If anyone has any help?Thanks!
Old Nov 24, 2007 | 10:25 AM
Probably easier to get a rebuilt or used pump. Check car-part.com for a local salvage yard for used.
Old Nov 26, 2007 | 06:53 PM
iridebmx33's Avatar
Thanks...I found a used one for $30 at a junk yard and I think I'm going to go with that. Thanks for your help!
Meter an
Jan 3, 2017 04:22 PM
PGRNPA
Sep 29, 2013 09:30 AM
divinations
May 31, 2013 07:52 PM
MessAround
Nov 4, 2012 06:51 PM
inthedump
Oct 28, 2009 09:35 PM
